Trace |
Trace(MessageText, [LogTimeStamp], [BreakLine])
This method allows registering messages in E3's log. This method can be used, for example, to register debugging messages for scripts executed in E3 Viewer.
Parameters of the Trace method
Parameter |
Description |
MessageText |
A user-defined message |
LogTimeStamp |
A Boolean indicating whether each record must contain a timestamp. This parameter is optional and ignored in E3 Viewer |
BreakLine |
A Boolean indicating whether a line break must exist at the end of each message. This parameter is optional and ignored in E3 Viewer |
