EnableHeartbeat
EnableHeartbeat
Boolean Enables or disables sending a heartbeat message (sent at fixed intervals, which indicates that the server is active) between an E3 Viewer and a server. In case E3 Viewer stops receiving heartbeat messages, this means that a problem occurred, therefore connection must be aborted. Default value of this property is False.
