EnableScaling |
If this property is set to True, any value coming from a device suffers a scale adjustment according to the EUHigh and EULow properties before setting it to the Value property. If the EnableScaling property is set to False, no scale adjustment is performed in both directions (writing or reading). Default value of this property is False.
