TimeoutCall
TimeoutCall
Number Read-and-write property specifying a time limit for a call to an OPC UA server, in milliseconds. This property cannot be changed while communication is active, its value must be greater than 0 (zero), and its default value is 10,000 (10 seconds).
NOTE
In OPC UA standard, several calls allow to continue communication, with multiple responses from the server. So, this time ends up being the limit time for a response from the OPC UA server.
