Min
Min
Number This property specifies the lowest source value for a Table Row. The next example is applicable for both Max and Min properties.
Sub CommandButton1_Click()
  Set Bind = _
    Screen.Item("Rectangle1").Links.Item("ForegroundColor")
  Set Line1 = Bind.Item(1)
  Line1.Min = 0
  Line1.Max = 20
  Set Line2 = Bind.Item(2)
  Line2.Min = 21
  Line2.Max = 100
