ClearFailure
ClearFailure
ClearFailure(FailureName)
This method must be called to indicate that a failure reported by the ReportFailure method is no longer active. The FailureName parameter specifies a failure name (user-defined) and must be passed to the ReportFailure method when that method is called.
