CanGrow
CanGrow
Boolean Determines whether to apply a stretch effect to a Section of a Report. In case a Section's width or height increase, its text accompanies this variation. If this property is set to True, the text accompanies Section's height and width variations. Otherwise, the Section remains with its initial settings. Default value of this property is True.
