ProportionalThumb
ProportionalThumb
Boolean This property specifies whether a Scrollbar size is equal to its dimension. If this property is set to True, Scrollbar's box has the same dimensions of this object. Otherwise, if this object is resized, Scrollbar's box remains with its original size. Default value of this property is True.
