LargeChange
LargeChange
Number Specifies the amount of steps for Scrollbar's cursor. This property's value is the amount that the Value property changes when users click the area between Scrollbar's box and Scrollbar's cursor. Any integer value is allowed for this property, but the recommended interval is from -32,767 to +32,767, as this value must be between the values determined by Scrollbar's Max and Min properties.
