GetExportFilter
GetExportFilter
GetExportFilter(FilterName)
Returns an object specifying custom export parameters for a Report. This method contains a FilterName parameter, which indicate a type of format for exporting. The available options for the FilterName parameter are the following:
PDF: Exports data to PDF (Portable Document Format) format
Excel: Exports data to Excel's spreadsheet format
HTML: Exports data to HTML (Hyper Text Markup Language) format
TEXT: Exports data to Text format
RTF: Exports data to RTF (Rich Text Format) format
TIFF: Exports data to TIFF (Tag Image File Format) format
After retrieving a filter, all properties described on the next table can be modified.
Available properties on an export filter
Property
Filter
Description
AutoRowHeight
Excel
In True (default), automatically configures a row's height. In False,configures size to the largest element on a row
BorderSpace
Excel
Minimum space between cells. Default value is 59 twips
CreateCSSFile
HTML
If True, generates a CSS file on the directory indicated by HTMLOutputPath
DoubleBoundaries
Excel
In True, indicates that elements aligned to the right must replace the ones aligned to the left on the same column. Otherwise, leave it in False to free more space
ExportRange
HTML
Indicates a range of pages for exporting, such as "1, 2, 3-9, 14"
FaxExport
TIFF
Object that allows exporting data in RFC 1314 TIFF format
FileName
All
Informs the name of a file to which data is exported
GenPageBreaks
HTML
In True, places page breaks under the lowest element in each Report's page
HTMLOutputPath
HTML
Default path for HTML files
JPGQuality
PDF
Indicates the quality level of exported images, between 0 (zero) and 100
MinColumnWidth
Excel
Minimum size of a column. Default value is 1011 twips
MinRowHeight
Excel
Minimum size of a row
MultiSheet
Excel
In True, each Report page goes to a separate spreadsheet
PageDelimiter
Text
Configures or returns a delimiter character between pages
SuppressEmptyLines
Text
Removes or inserts empty lines, for layout purposes
TextDelimiter
HTML
Configures or returns a delimiter character between texts
TrimEmptySpace
Excel
In True, the vertical space between elements is removed. Default is False
Unicode
Text
Determines whether text is saved in Unicode format (16 bits) or not
WebCacheOutput
HTML
In True, a Report is exported to the WebCache service. Otherwise (default), it is not exported
