DataType
DataType
Enum Determines the data type associated to this OPC Block. This is a read-only property. Possible values for this property are described on the next table.
Available options for the DataType property
Option
Description
0 - _Undefined
Unidimensional undefined value (empty, default)
1 - _Null
Null value
2 - _Integer
Unidimensional 16-bit signed integer value
3 - _Long
Unidimensional 32-bit signed integer value
4 - _Single
Unidimensional 32-bit floating point value
5 - _Double
Unidimensional 64-bit floating point value
6 - _Currency
Unidimensional currency value with four decimal places
7 - _Date
Date and time value
8 - _String
Literal value (text)
9 - _Object
Unidimensional reference value to an object
10 - _Error
Unidimensional error code value
11 - _Boolean
Unidimensional Boolean value (True or False)
12 - _Variant
Data of any type used for objects and other values to which the data type is unknown
13 - _UnkObject
14 - _Decimal
Unidimensional 96-bit floating point value
36 - _Record
Unidimensional recording value
16 - _Char
Unidimensional 8-bit integer value
17 - _Byte
Used to create DLLs and OLE, uses one byte in memory
18 - _Word
Unidimensional 16-bit integer value
19 - _Dword
Unidimensional 32-bit integer value
20 - _LongLong
Unidimensional 64-bit signed integer value
21 - _DDWord
Unidimensional 64-bit integer value
22 - _Integer_
Integer number, ranges from -32.768 to 32.767, uses two bytes
23 - _Uinteger
Unsigned integer value (equivalent to a DWord), ranges from 0 (zero) to 4294967295 (232 - 1)
8194 - _ArrInteger
Unidimensional array of integer values
8195 - _ArrLong
Unidimensional array of 32-bit signed integer values
8196 - _ArrSingle
Unidimensional array of 32-bit floating point values
8197 - _ArrDouble
Unidimensional array of 64-bit floating point values
8198 - _ArrCurrency
Unidimensional array of currency values with four decimal places
8199 - _ArrDate
Unidimensional array of date and time values
8200 - _ArrString
Unidimensional array of literal values (text)
8201 - _ArrObject
Unidimensional array of reference values to an object
8202 - _ArrError
Unidimensional array of error code values
8203 - _ArrBoolean
Unidimensional array of Boolean values (True or False)
8204 - _ArrVariant
Array of data of any type used for objects and other values to which the data type is unknown
8205 - _ArrUnkObject
8206 - _ArrDecimal
Unidimensional array of 96-bit floating point values
8228 - _ArrRecord
Unidimensional array of record values
8208 - _ArrChar
Unidimensional array of char values
8209 - _ArrByte
Unidimensional array of bytes, which are values used to create DLLs and OLE, uses one byte in memory
8210 - _ArrWord
Unidimensional array of 32-bit integer values
8211 - _ArrDWord
8212 - _ArrLongLong
Unidimensional array of 16-bit integer values
8213 - _ArrDDWord
8214 - _ArrInteger_
Unidimensional array of 16-bit signed integer values
8215 - _ArrUInteger
Unidimensional array of unsigned integer values (equivalent to a DWord), ranges from 0 (zero) to 4294967295 (232 - 1)
