Run Application
Run Application
Executes a specific application.
Settings for the Run Application Pick
Available options for Run Application Pick
Option
Description
Command
By clicking Browse, users can browse the disk to select an application file to execute
Parameters
Allows specifying arguments for application's call
Start in folder
Determines the working directory of the application to execute
Window type
Determines the type of the execution window for the application. Possible values are Normal, Minimized, or Maximized
