PicturePosition
PicturePosition
Enum This property specifies the position of a picture set to an object relative to its legend. Available options for this property are described on the next table.
Available options for the PicturePosition property
Option
Description
0 - fmPicturePositionLeftTop
Picture appears on legend's left side. This legend is aligned to picture's upper side
1 - fmPicturePositionLeftCenter
Picture appears on legend's left side. This legend is centered relative to the picture
2 - fmPicturePositionLeftBottom
Picture appears on legend's left side. This legend is aligned to picture's lower side
3 - fmPicturePositionRightTop
Picture appears on legend's right side. This legend is aligned to picture's upper side
4 - fmPicturePositionRightCenter
Picture appears on legend's right side. This legend is centered relative to the picture
5 - fmPicturePositionRightBottom
Picture appears on legend's right side. This legend is aligned to picture's lower side
6 - fmPicturePositionAboveLeft
Picture appears above the legend. This legend is aligned to picture's left side
7 - fmPicturePositionAboveCenter
Picture appears above the legend. This legend is centered below the picture (default)
8 - fmPicturePositionAboveRight
Picture appears above the legend. This legend is aligned to picture's right side
9 - fmPicturePositionBelowLeft
Picture appears below the legend. This legend is aligned to picture's left side
10 - fmPicturePositionBelowCenter
Picture appears below the legend. This legend is centered above the picture
11 - fmPicturePositionBelowRight
Picture appears below the legend. This legend is aligned to picture's right side
12 - fmPicturePositionCenter
Picture appears at the center of the control. The legend is centered horizontally and vertically on top of the picture
