HideSelection
HideSelection
Boolean This property specifies whether the selected text is still highlighted when an object does not have focus anymore. If this property is set to True, the selected text is not highlighted, unless this object has focus. Otherwise, the selected text always appears highlighted. Default value of this property is True.
