DragBehavior
DragBehavior
Boolean Enables or disables a feature of dragging and dropping a text on an object's content. Available options for this property are the following:
0 - fmDragBehaviorDisabled: Does not allow dragging and dropping a text on an object's content
1 - fmDragBehaviorEnabled: Allows dragging and dropping a text on an object's content
Default value of this property is 0 - fmDragBehaviorDisabled.
NOTE
This property has no effect if the Style property is set to 2 - fmStyleDropDownList.
