AutoTab
AutoTab
Boolean This property enables or disables automatic tab on an object. If this property is set to True, automatic tab occurs. Otherwise, it is not used.
After users type the maximum number of characters on an object (by using the MaxLength property), focus moves automatically to the next object in its tab order, whenever these characters are reached. For example, for a Text to always display stock data with five characters, users can use the MaxLength property to specify the maximum number of characters to type in an object and this property to automatically move to the next object after users type five characters.
