AutoSize
AutoSize
Boolean This property adjusts text width, if the available area exceeds object's size. For a Text object, when this property is set to True, text width is resized to the same object's width. Default value of this property is False.
NOTE
It is advisable to avoid using this property with a Text that also uses the Multiline and WordWrap properties. When users type into a Text with these properties set to True, it automatically resizes itself as a long and narrow text box, with a one-character width and a one-text-row size.
