ListStyle
ListStyle
Enum This property determines the object's list style. The available options for this property are the following:
0 - fmListStylePlain: List with background items highlighted (default)
1 - fmListStyleOption: Displays option buttons or combo boxes for a list with several options. When users select one item on the group, the option button associated to this item is selected and the option buttons for the other group items are deselected
NOTE
The 1 - fmListStyleOption option can only be enabled if the MultiSelect property is set to 1 - fmMultiSelectMulti.
