IntegralHeight
IntegralHeight
Boolean This property adjusts the height of text's editing area, if the available area exceeds the object's size. If this property is set to True, the height of text's editing area is adjusted to match the object's current size, thus allowing a full display of text's content. Otherwise, text's editing area keeps its original size. If a text is larger than the available space, it is not displayed in the object.
