SpecialEffect
SpecialEffect
Enum This property specifies object's appearance. Available options for this property are described on the next table.
Available options for the SpecialEffect property
Option
Description
0 - fmSpecialEffectFlat
Object appears flat and has a raised border, a color change, or both
1 - fmSpecialEffectRaised
Object is raised on its upper left side and a shadow on its lower right side, as a relief
2 - fmSpecialEffectSunken
Object has a shadow on its upper left side and raised on its lower right side. This object and its border appear sunken on a Screen (default)
3 - fmSpecialEffectEtched
Border looks etched around object edges
6 - fmSpecialEffectBump
Object has a ledge on its lower right side and looks flat on its upper left side
