MatchRequired
MatchRequired
Boolean Specifies whether a user-typed text must match existing items on a Combo. If this property is set to True, users cannot leave a Combo until the text inserted matches an item on this object. Otherwise, the inserted text on a Combo can be different from all existing data on its list.
