CurX
CurX
Number This property specifies the current horizontal position of an object's insertion point. This property is applied to an object with several rows, that is, whose Multiline property is enabled. Returned value is valid when this object has focus. Users can use the Multiline property and this property to place a text's insertion point as users use the scroll bar on object's content. When users move the insertion point to another row in a text by scrolling object's content, the CurTargetX property specifies the most appropriate position for text's insertion point. This property is defined with this value if the text row is greater than the value of CurTargetX. Otherwise, this property is defined at the end of text's row. This is a read-only property.
