RemoveLink
RemoveLink
RemoveLink(Property)
This method removes a Link from a property specified by Property, if it exists. If a Link to the specified property does not exist, this method has no effect. Example:
Sub CommandButton2_Click()
  On Error Resume Next
  Dim Bind
  Set Bind = Screen.Item("ScrollBar1").Links.Item("Value")
  If Bind Is Nothing Then
    ' If the link does not exist
    MsgBox "ScrollBar1 is not linked."
  Else
    MsgBox "ScrollBar1 is linked to '" & Bind.Source & "'"
    MsgBox "Removing the link."
    Screen.Item("ScrollBar1").Links.RemoveLink("Value")
  End If
