Write
Write
Write(Value)
Sends the String passed on the Value parameter to the printer selected on the Line Printer object. If the value passed by this method exceeds the number of pending lines configured in the MaxPendingLines property, this method returns an error and the String is discarded.
The Value parameter is sent to the configured printer as raw data, that is, without any type of formatting. To print special characters, such as new lines or tabs, use String constants or VBScript's Chr method, which receives the ANSI code of the character to print. The next table contains the most common constants for printing to dot-matrix printers. For more information about specific characters, please check the user's manual of the printer to use.
Most common constants for printing special characters
Constant
Value
Description
vbCr
Chr(13)
Carriage-return character
vbLf
Chr(10)
Linefeed character
vbCrLf
Chr(13) & Chr(10)
Carriage-return and linefeed characters
vbNewLine
Chr(13) & Chr(10) ou Chr(10)
Carriage-return and linefeed characters or only linefeed character, depending on the printer used
vbTab
Chr(9)
Tab character
