UseDefaultPrinter
UseDefaultPrinter
Boolean Configures the Line Printer object to use Windows default printer. Default value for this property is True.
NOTES
If this property is configured as False and the PrinterName property is configured with an empty String, users cannot print and the PrinterStatus property returns the value 0 (zero, psUnknown).
Windows default printer for the currently logged-in user may be different from the default printer used by E3 Server. This printer is identified by the icon Impressora padrão do E3 Server on E3 Admin - Printer window (right-click E3 Admin's icon on Windows Notification Area and select the Printer option).
