MinRecTime
MinRecTime
Number Minimum difference, in milliseconds, between timestamps of any two records with the same quality stored on a database, that is, the minimum time to store new data. This parameter is used to limit the number of records written to a database, in case a Tag experiences abrupt variations in its value. This behavior can be disabled by using the value 0 (zero, default value).
