DeleteField
DeleteField
DeleteField(Index)
Removes the Historic Field informed in the Index parameter, which can be a Historic Field's position (starting at one) or a Historic Field's Name property, if that Historic Field exists on the Fields object. Otherwise, this method returns a script error.
NOTE
The E3TimeStamp Historic Field, created automatically by E3, cannot be removed.
