WordWrap
WordWrap
Boolean Enables or disables a line break in a text, if the available area for this text overrides the limits determined by a SetPoint object. For this property to work, the MultiLine property must be equal to True. If it is False, the white-space:nowrap configuration appears in the Style property.
