SummaryRunning
SummaryRunning
Enum Determines whether a summary of running values is performed, according to the following options:
0 - ddSRNone: Does not perform this summary calculation (default)
1 - ddSRGroup: Calculates the summary of running values for each range of specified total values
2 - ddSRAll: Calculates the summary of running values of all values in the Report, regardless of groupings
This property is only valid when the SummaryType property is different from 0 (zero).
