SubConditionName
SubConditionName
Text Name of a subcondition, if it is an Alarm Event. Possible values for this property are:
DB: Dead Band alarm
DIG: Digital alarm
ROC: Rate of Change alarm
LOLO: Analog alarm on a Very Low range
LO: Analog alarm on a Low range
HI: Analog alarm on a High range
HIHI: Analog alarm on a Very High range
NOTE
For Discrete-type Alarm Sources, this property assumes the name of the user-defined Subcondition, which is available on the Discrete tab of properties of this type of Alarm.
If this Event is not an Alarm, this property is equal to an empty String. This is a read-only property.
