Numeric
Numeric
Number Read and write property identifying this object, in case the Type property is equal to 0 - nitNumeric. If the Type property is different from 0 (zero), reading this property returns an error. Writing to this property always forces the Type property to change to 0 (zero). Setting this property to 0 (zero) identifies this object as Null.
