OrderNumber
OrderNumber
Number Order number of this Field relative to the other Fields forming the Query's sort order. This value will only be accepted as a number greater than 0 (zero) if the Field contains a sort type (defined by the OrderBy property). This value must be less or equal to the number of Fields forming the Query's sort order.
