AddUaField
AddUaField
AddUaField(Name, [Alias], [Aggregate])
This method adds, at run time, a field to a query configured as an OPC UA-type. This method returns True if successful and False on failure. The parameters of this method are the following:
Name: A String with the path (Column) of the field
Alias: A String with the title of the field. If this parameter is omitted, assumes an empty String
Aggregate: A String with the type of aggregation function of the field, in case a Processed Data-type query is used. If this parameter is omitted, assumes the value Interpolative
In a Raw Data-type query (the UaQueryType property equal to zero), this method fails if there is already a defined field. This method is only effective if the QueryType property is configured as OPC UA (value equal to 2: qtOpcUa). Otherwise, it returns False.
