SourceTypeName
SourceTypeName
SourceTypeName(SourceType)
Returns a String with a description of the active Measurement Source (the ActiveSource property of Analog Measurement and Discrete Measurement objects in Elipse Power). This method is available in Links, as well as in scripts. Possible values for SourceType parameter are the following:
-1: Empty String
0: Active Source
1: SCADA
2: Operator
3: Control Center
4: Billing
5: Calculated
6: Database
100: Topology Processor
101: Power Flow
102: State Estimator
103: Load Shedding
104: Distribution Load Modelling
105: Self-Healing
106: External Reader
NOTE
In case the value passed on SourceType parameter is not one of the possible values, this method returns a String "???".
