OPCGetSubStatus
OPCGetSubStatus
OPCGetSubStatus(Quality)
Returns the Substatus information (from 0 to 15) of an OPC Quality specified by the Quality parameter. This method is available in Links, as well as in scripts. The OPC Standard specifies the following values:
Good Quality:
0: Non-specific
1: Local override
Bad Quality:
0: Non-specific
1: Configuration error
2: Not connected
3: Device failure
4: Last known value
5: Communication failure
6: Out of service
Uncertain Quality:
0: Non-specific
1: Last usable value
4: Sensor not accurate
5: EU exceeded
6: Subnormal
