MsgBoxEx
MsgBoxEx
MsgBoxEx(prompt, [buttons], [title], [PosX], [PosY])
This method allows displaying a default Windows dialog box and specify its position on the screen. The available parameters in this method are the following:
prompt: Text to display on the dialog box. The maximum size of this text is approximately 1024 characters, depending on the width of the characters used. To insert line breaks on this text, separate these lines using VBScript's Chr function with values 10 (linefeed), 13 (carriage return), or a combination of these values between each line
buttons: An optional numerical expression that represents the sum of values specifying the number and type of buttons displayed, style, default button, and whether this dialog box is modal or not. The default value of this parameter is 0 (zero), that is, only displays the OK button. Please check the next table for more information about this parameter
title: An optional text displayed on the title bar of this dialog box. If this parameter is omitted, this dialog box does not show any title
PosX: Indicates the position, in pixels, of this dialog box relative to the window's left margin. If this parameter is omitted, the respective dialog box's coordinate is centered on the window
PosY: Indicates the position, in pixels, of this dialog box relative to the window's top margin. If this parameter is omitted, the respective dialog box's coordinate is centered on the window
NOTE
If the values indicated in the PosX and PosY parameters place this dialog box outside the visible area, those values are automatically adjusted to ensure this dialog box is visible.
Possible values for the buttons parameter are described on the next table.
Value
Description
Constant in VBScript
Type of Button
0
Displays only the OK button
vbOKOnly
1
Displays the OK and Cancel buttons
vbOKCancel
2
Displays the Abort, Retry, and Ignore buttons
vbAbortRetryIgnore
3
Displays the Yes, No, and Cancel buttons
vbYesNoCancel
4
Displays the Yes and No buttons
vbYesNo
5
Displays the Retry and Cancel buttons
vbRetryCancel
Style of Icons
16
Displays an icon indicating a critical message
vbCritical
32
Displays an icon indicating a question
vbQuestion
48
Displays an icon indicating a statement
vbExclamation
64
Displays an icon indicating an information
vbInformation
Default Button
0
Indicates that the first button is the default return
vbDefaultButton1
256
Indicates that the second button is the default return
vbDefaultButton2
512
Indicates that the third button is the default return
vbDefaultButton3
768
Indicates that the fourth button is the default return
vbDefaultButton4
Type of Modal Window
0
Indicates that users must respond this dialog box before continuing work on the application
vbApplicationModal
4096
Indicates that all applications are suspended until users respond this dialog box
vbSystemModal
This method returns a number representing the button clicked on the dialog box, according to the next table.
Return values of the MsgBoxEx method
Value
Button
1
OK
vbOK
2
Cancel
vbCancel
3
Abort
vbAbort
4
Retry
vbRetry
5
Ignore
vbIgnore
6
Yes
vbYes
7
No
vbNo
