DwordToLong
DwordToLong
DwordToLong(Value)
Converts an unsigned 32-bit value, in the range between zero and 4,294,967,296, passed to the Value parameter to a signed 32-bit value, in the range between -2,147,483,648 and 2,147,483,647, with the same pattern of bits. If the value is in the range between zero and 2,147,483,647, it is returned unchanged.
NOTE
If the value passed in the Value parameter is a floating point value, only this value's integer part is used.
