Type |
Defines an E2Button's type. Possible values for this property are the following:
•0 - ButtonTypeKey: Standard button behavior (default)
•1 - ButtonTypeSwitchH: This button's behavior is a switch horizontally divided
•2 - ButtonTypeSwitchV: This button's behavior is a switch vertically divided
•3 - ButtonTypeLeverH: This button's behavior is a lever that moves from left to right and vice versa
•4 - ButtonTypeLeverV: This button's behavior is a lever that moves from top to bottom and vice versa
•5 - ButtonTypeTransparent: This button is transparent
•6 - ButtonTypeUserBitmap: This button alternates pictures defined in the Bitmap0 and Bitmap1 properties
•7 - ButtonTypeCheckbox: This button's behavior is the same as a Check Box
•8 - ButtonTypeRadio: This button's behavior is the same as a Radio Box
