VertTextAlignment
VertTextAlignment
Enum Determines a vertical alignment for an object's text. Possible values for this property are described on the next table.
Available options for the VertTextAlignment property
Option
Description
0 - TopAlignment
Text's vertical alignment is on top of this object
1 - MidAlignment
Text's vertical alignment is centered in this object (default)
2 - BottomAlignment
Text's vertical alignment is at the bottom of this object
