Value
Value
Variant This property is a Variant, which may assume any and every type of value displayed by an object. Usually this property contains a text, because it is automatically filled in when creating a new Text object. The IsSetPoint property is used to determine whether a Text object has the same behavior of a SetPoint, that is, allows editing this property. Example:
Sub DrawString1_OnStartRunning()
  ' Reads a value from a Tag and displays its Text
  Dim obj
  Set obj = Application.GetObject("DataServer1.DemoTag1")
  Value = "DemoTag1 value = " & obj.Value
