Format
Format
Text This property specifies a format type to attribute to this object. It allows changing the way data is displayed without changing their values. This property can be edited manually or configured using a format window. Its usage is similar to formats used on spreadsheets, following the same syntax. The next table contains all supported data types.
Data types supported by the Format property
Datatype
Description
Number
Decimal, scientific, hexadecimal, binary, or octal output
Text
General text
Boolean
Boolean values
Date/Time
Gregorian calendar
