VerticalPercentFill
VerticalPercentFill
Number Use this property to specify a percentage of this object's vertical area to fill. Acceptable values for this property range from 0 (zero) to 100. This property works along with the VerticalFillStyle property, which informs how this fill occurs. Default value of this property is 100.
