TransparentMode
TransparentMode
Enum This property specifies a transparency effect mode for this picture. The next table contains possible values for this property.
Available options for the TransparentMode property
Option
Description
0 - Disabled
No transparency is performed (default)
1 - ByColor
Transparency uses a color defined in the TransparentColor property
2 - ByPercent
Picture remains transparent with a transparency percentage specified in the TransparentPercent property
Example:
Sub DrawPicture1_Click()
  ' Leaves the blue color transparent
  ' when clicking this object
  TransparentMode = 1 ' ByColor
  TransparentColor = RGB(0, 0, 255)
