ShadowY
ShadowY
Number Defines an upper horizontal coordinate for this object's shadow, in Himetric units. This shadow is always relative to this object's Y property. Positive values indicate that this shadow is under the object, and negative values that it is above the object. Default value of this property is 200.
NOTE
This property is only effective when a Picture object is working with Metafiles (WMF or EMF).
