OverrideFillMode
OverrideFillMode
Enum This property specifies a fill mode for this object's picture, when displaying a Windows Metafile. It changes the picture's original fill mode without changing the file defined in the Filename property. The next table contains valid values for this property.
Available options for the OverrideFillMode property
Option
Description
0 - NoOverride
Picture keeps its original fill (default)
1 - Wideframe
Picture is not filled
2 - SolidFill
Picture is filled with the color specified by the OverrideFillColor property
3 - ByBrightness
Picture is filled with the color specified by the OverrideFillColor property, but considers the intensity of picture's original color
Example:
Sub DrawPicture1_Click()
  ' When clicking this object sets the
  ' Override mode to solid
  ' and changes picture's fill
  ' color to blue
  OverrideFillMode = 2
  OverrideFillColor = RGB(0, 0, 255)
NOTE
This property is only effective when a Picture object is working with Metafiles (WMF or EMF).
