EnableOverrideLineColor
Boolean This property enables or disables an object to overwrite the original color of a picture's line by the color defined in the OverrideLineColor property. If this property is enabled, it allows modifying the original color of an object's line by the color of the OverrideLineColor property. Otherwise, a Picture object displays its original color.
