PolygonFill
PolygonFill
Enum This property configures the fill mode of a Polygon's area. To determine whether this area must be filled or not, a line is drawn starting at a p point towards infinity without crossing any vertexes. Possible values for this property are the following:
0 - Alternate: If the drawn line crosses an odd number of lines, the Polygon's area is then filled. Otherwise, the Polygon's area is not filled
1 - Winding: In this mode, a counter is defined to determine whether the area is inside or outside the Polygon. If the Polygon's line crosses the drawn line clockwise, then 1 (one) is subtracted from this counter. If the Polygon's line crosses the drawn line counterclockwise, then 1 (one) is added to this counter. If at the end this counter is equal to 0 (zero), the area is not inside the Polygon and therefore not filled. If the counter is different from 0 (zero), the area is inside the Polygon and therefore it is filled
