OverrideLineColor
OverrideLineColor
Color When the EnableOverrideLineColor property is set to True, this property is used to define a color to use on object's line of a Group, instead of their original colors. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is red (RGB(255, 0, 0)).
