ScaleY
ScaleY
Number This property indicates the Y scale of an E3Chart to which this Pen is linked. The scale configured for this property has a vertical orientation, that is, it can be positioned to the left or to the right of an E3Chart. Example:
Sub CommandButton1_Click()
  Set Chart = Screen.Item("E3Chart1")
  Set Pen = Chart.Pens.AddPen("DemoTagPen2")
  Pen.YLink = "Data.DemoTag2"
  Pen.UseTimeStamp = True
  ' The scale must exist.
  Pen.ScaleY = "ScaleForDemoTag2"
  Pen.Connect()
This property has no effect when the UseAutomaticAxis property is set to True.
