EnableAutoPlotMode
EnableAutoPlotMode
Boolean Enables an automatic mode of connection of points of an Automatic-type of Pen. Default value of this property is True. When configuring this property in True, the DigitalData property is not used to connect points. If users want to overwrite the way to connect points of a Pen received from a server, they can configure this property in False and configure the DigitalData property to the desired way, that is, configure in True for a digital connection and in False for an analog connection.
